21 years agoNios-I speed in QuartusII 5.0
Hi, I've just moved from Quartus 4.0 to Quartus 5.0, re-generated my Nios sub-system using SoPC Builder, and the run the Cyclone-based design through Quartus syhthesis and place & route. ...
21 years agoI could have sworn I saw this posted somewhere else.
Check your Quartus project settings to make sure nothing was modified in the upgrade (a lot has changed since 4.0). I have noticed "Auto Fit" being turned on sometimes after the upgrade and you want that to be set to "Standard" in most cases. Here's a set I find useful for big designs like the standard and full-featured reference designs: Multiplexer restructuring --> off State machine encoding --> one hot (make sure you don't have any large statemachines in your design since they will become very big) Standard fitter effort Combinational physical synthesis Normal physcial synthesis effort Hope that helps
