22 years agoNIOS I custom instructions
In NIOS I, when using custom instructions with a prefix value the documentation says for the C/C++ code that it takes an 11bit immediate value. I've never heard of immediate values in terms of C...
22 years agoYou can't use the 11 bit K register to pass an argument to a function: the K register is cleared after all instructions (except the PFX and PFXIO instructions used to set it), and the PFX opcode is not allowed in the branch delay slot. Thus, the K register will always be cleared by the CALL instruction invoking your routine.
Besides, using the PFX op-code restricts you to compile-time constant values (unless you want to resort to self modifying code), while using a normal register allows the value to be set a run time. In assembly speak, the term "immediate value" refers to a constant that is included as part of the op-code itself.
