12 years agoNios f / Custom MM Slave
Hi all, I know this has been asked several times on the forum but I must be missing the point as I'm still at encountering the issue. I have tested my SoPC fine with the nios e. The problems...
12 years agoalt_remap_uncached() simply returns a new pointer with bit 31 set. Your code fragment doesn't show you are doing anything with the return value, so perhaps this is the piece you are missing?
e.g.
alt_u32 *my_block = alt_remap_uncached( AVS_BASE, avsrange );
my_block = foo;
