ZKhan1
5 years agoNios Ethernet elf download error
Hi there , I am trying to run a simple loopback design using Triple Speed Ethernet on DE2-115 board . following this doc "Using Triple-Speed Ethernet on DE2-115 Boards". When i try to download and...
RadicalExponent
5 years agoHey,
I am experiencing the same problem with my project at the moment.
Using Quartus 18.0 (but also tried earlier versions like 16.0, 15.0, 13.0, standard each).
I came to recognize that, for a short while, there is an error message referencing some wrapper script
as can be seen in the image.
Trying to download only one file results in the same error.
EDIT: Little sidenote: Using the Nios II Command Shell and the command nios2-download worked fine...
