15 years agoNIOS EDS 9.1 does not detect USB connection.
Hi. I'm trying to download a NIOS program via USB. When I select "Run as -> Nios II Hardware", the Run Configuration dialog box appears. In the Target Connection tab, it seems that NIOS EDS can...
15 years agoI'm not sure what's causing that but you could use nios2-download and nios2-terminal from the command line to download the elf and open a terminal.
