16 years agoNIOS Eclipse 9.1 SBTfE: Assembly file checked out from CVS not being built
Hi, I've checked out a directory from CVS into a project via Eclipse. The directory contains a number of '.c' and a single '.S' file. All the files are shown, with the correct file types, in th...
16 years agoHi Pin9,
If you're really stuck you could probably use the kludge described in the original report - add a line like the following to the Makefile AFTER the 'GENERATED SETTINGS END' comment in the Makefile: ASM_SRCS += xxx.S Which will add xxx.S to the list of assembler sources but should not be touched by eclipse. I haven't tried this since the original report (as I don't need the pre-processor) but it may work for you.
