20 years agonios debug freezing
Normally,my design works well, but sometimes I do a little change in the fpga design,such as put a signal on an output pin for test. run nios ide. after nios finish downloud SW and jump in debug wi...
20 years agoIt's not unheard of that small design changes affect borderline timing on some other component (memory, I/O) to the point where the program crashes or the debugger can't communicate any more.
First thing to check might be the timing on RAM, if you have that.
