15 years agonios crash,but I don't know what the reason is
hi
i'm trying to use the nios and some other FPGA logic to achieve composing some inputs to a display, now it running right most of the time,but sometimes when startup or running for a long time ,it can't run, I found that the FPGA logic is still running but only the nios is crashed, the reset I think is OK and I can't find any reason to explain it and resolve it. so any one can help me thank U ~!2 Replies
Maybe your soft has a memory leak, a blocking routine, an overflow, a blocking mutex, a priority inversion... Do you use superloop or an OS like ucOS, FreeRTOS, ecos, uclinux ? Could you describe your soft ? Which components do you use ? ...? ... We have not enough information in order to answer. - Altera_Forum
superloop,I'don't know the details, I just do the part of FPGA logic,soft is done by others
