15 years agonios crash,but I don't know what the reason is
hi i'm trying to use the nios and some other FPGA logic to achieve composing some inputs to a display, now it running right most of the time,but sometimes when startup or running for a long tim...
15 years agoHi,
Maybe your soft has a memory leak, a blocking routine, an overflow, a blocking mutex, a priority inversion... Do you use superloop or an OS like ucOS, FreeRTOS, ecos, uclinux ? Could you describe your soft ? Which components do you use ? ...? ... We have not enough information in order to answer.
