22 years agoNios Compiler Bug - Any Workarounds
I have run into a bug with the version of GCC supplied with the Nios v3.02 development kit (2.9-nios-010801-20030520) when compiling with for 32 bit Nios (compiler flags -O0 -m32 -mflat). If I write ...
22 years agoOur client had the GCC version from the Nios 3.1 package installed (nios-elf-gcc -v reports version 2.9-nios-010801-20030718). Compiling the example code with this version produced the same result as the version I had: the bug is still present.
