13 years agoNios cannot open/access EPSC
Custom Cyclone IV based board. Uses EPCS16 (ST 25P16) for AS configuration of FPGA. Board successfully configures from the EPCS and will then boot Nios, also from the EPCS. However, Nios cannot...
13 years agoFinal note...
I have now implemented some hdl to perform the low level interface to the EPCS. Combined with a little code running on Nios I can successfully read, write and erase sectors, all that I need it to do. FYI, the sector erase (512kb in the EPCS16) takes just under 1 second. I'm still a little confused/disappointed with Eclipse as to why Altera's IP for the EPCS doesn't want to let me access it from Nios. Any further thoughts from anyone would be welcome.
