13 years agoNios C-Code Size
Sorry if I am being a bit thick here. Been programming VHDL forever but C is still a little bit of a mystery to me. Can someone please tell me if there is a quick and easy way of working out ho...
13 years agoIf you are tight on memory it is worth making sure your code isn't using any libarary functions that you don't explicitly need.
IIRC even the 'small' BSP has a lot of extra stuff, the normal one is ridiculous. Altera ought to supply a 'minimal' example that contains absolutely nothing that isn't strictly necessary, and is designed for separate tightly coupled instruction and data memories (no caches). (It is a shame you can't connect the boot code (JTAG or EPCS) as tightly coupled instruction memory). Make sure you are compiling everything with -O2 (or -O3), not the default unoptimised - which will generate a lot more code. As well as the .map file, nios2-elf-objdump has options to show the symbol tables and disasembly of any of the object files.
