20 years agoNIOS Build Problem
I am trying to make a build on NIOS 3.2.. While compiling core, SDK Shell is giving following messages.. Its not generating '.srec' file.. Please suggest me whats the problem. -------------------- Beginning Build -------------------- Sources: bcd_ieee754_converter.c i2c.c ls_mngr.c spi_mngr.c main.c # 2006.10.20 00:23:15 (*) nios-elf-gcc -I .. -I ../.. -I ../inc -I ../../inc -I ../../../inc -I ../../../../inc -I ../../../../../inc -W -Wno-multichar -g -mno-zero-extend -O2 -m32 bcd_ieee754_converter.c -o bcd_ieee754_converter.c.o -c # 2006.10.20 00:23:15 (*) nios-elf-gcc -I .. -I ../.. -I ../inc -I ../../inc -I ../../../inc -I ../../../../inc -I ../../../../../inc -W -Wno-multichar -g -mno-zero-extend -O2 -m32 i2c.c -o i2c.c.o -c # 2006.10.20 00:23:16 (*) nios-elf-gcc -I .. -I ../.. -I ../inc -I ../../inc -I ../../../inc -I ../../../../inc -I ../../../../../inc -W -Wno-multichar -g -mno-zero-extend -O2 -m32 ls_mngr.c -o ls_mngr.c.o -c # 2006.10.20 00:23:16 (*) nios-elf-gcc -I .. -I ../.. -I ../inc -I ../../inc -I ../../../inc -I ../../../../inc -I ../../../../../inc -W -Wno-multichar -g -mno-zero-extend -O2 -m32 spi_mngr.c -o spi_mngr.c.o -c # 2006.10.20 00:23:16 (*) nios-elf-gcc -I .. -I ../.. -I ../inc -I ../../inc -I ../../../inc -I ../../../../inc -I ../../../../../inc -W -Wno-multichar -g -mno-zero-extend -O2 -m32 main.c -o main.c.o -c # 2006.10.20 00:23:16 (*) nios-elf-ld -e _start -u _start -g -T e:/altera/quartus60/sopc_builder/bin/excalibur.ld ./obj32/nios_jumptostart.s.o bcd_ieee754_converter.c.o i2c.c.o ls_mngr.c.o spi_mngr.c.o main.c.o --start-group -l nios32 -l c -l m -l gcc --end-group -L/cygdrive/e/altera/kits/nios/bin/nios-gnupro/nios-elf/lib/m32 -L/cygdrive/e/altera/kits/nios/bin/nios-gnupro/lib/gcc-lib/nios-elf/2.9-nios-010801-20030718/m32 -L../lib -L../../lib -L../../../lib -L../../../../lib -L../../../../../lib -L../inc -L../../inc -L../../../inc -L../../../../inc -L../../../../../inc -L. -o main.out # ## nios-build error: last system call returned256 # ## (Perhaps you need ".global _start" and "start:") spi_mngr.c: In function `spi_isr': spi_mngr.c:140: warning: `freqbasechg_sts' might be used uninitialized in this function spi_mngr.c:140: warning: `freqoffchg_sts' might be used uninitialized in this function nios-elf-ld: cannot open ./obj32/nios_jumptostart.s.o: No such file or directory Died at - line 85.2 Replies
Very complicated and designated message, looks like you are missing .o file for standard Nios II component.
You can check the system library of your Nios II project, if missing specific file I will suggest reinstallation. - Altera_Forum
Where is this nios_jumptostart.s supposed to come from? If it's yours, try changing the .s to .S (capital S).
