21 years agoNios board couldn't work with SignaltapII
hi: The board i use is nios pro stratix 1s40,when i program my sof file down to the FPGA, it just ok. but then i use signaltapII to debug my froject, the case is that it often reload the sof ...
21 years agothank you for reply.
The fact is that the project i program didn't have a Nios CPU, i want to use SignaltapII to check my project. As i set the unused pins as inputs & tri-state , so the CPLD didn't load the sof file from flash,(because the LED "loading"didn't turn on);but as i add signaltapII to my module ,when i program down to the board,CPLD load the sof file from flash,the LED "loading" blinking and then the LED "user" turn on.so the signaltapII just couldn't work. The board i use is nios pro stratix 1s40,i think something in signaltapII was set wrong like pins.
