21 years agoNios board couldn't work with SignaltapII
hi: The board i use is nios pro stratix 1s40,when i program my sof file down to the FPGA, it just ok. but then i use signaltapII to debug my froject, the case is that it often reload the sof ...
21 years agoAre you saying that you can't sample using SignalTap or that your embedded design stopped working? We will need more info to be able to help you out. (Provide as much detail as possible to get the best possible solution)
