12 years agoNios AvalonMM clock crossing bridge writes only 8 bits
Hi, I have a Nios II with the data master port (32 bit) connected to a Avalon-MM Clock Crossing Bridge to the CRA port of the PCIe core (in a Cyclone V), in Qsys. When I'm looking at the b...
12 years agoAh, yes. It seems that the IDE (Elcipse) doesn't generate a full 32 bit write on the Avalon bus, but generates 4 writes for each byte using the byte enables, when you manually change a value in the memory window.
Thanks !
