11 years agoNios and tcl script writing to RAM
Hi, I have an image loaded with a Nios , Jtag master and jtag UART. I have wrote C code to write to the on-chip RAM. I have also a tcl script that can read and write to the RAM. When ...
11 years ago --- Quote Start --- If I reload the other image with everything included, I am reading the correct values again across C and tcl. --- Quote End --- My suggestion would be to start with your functional image, and repeat the process of removing components until you break it. Remove one half of them, test it. Remove the other half, test it. And so on. Overall your problem sounds like operator-error in the process of having removed those components.
