12 years agonios address problem
hi everyone! i am new to altra and nios II, recently i am trying to study altra fpga and nios II, i meet one serious problem and i need some help i add 3 my ip in the Qsys, seg7(to drive t...
12 years ago --- Quote Start --- While it uses byte addressing, Nios master is 32bit wide and will access MM slaves with 32bit R/W. Then your base addresses must be aligned to multiple of 4, otherwise overlaps or data misalignment occur. Change base addresses to 0x11050 , 0x11054 and 0x11058 --- Quote End --- hi, thanks for the help! i think that is the reason! but when i use "system=>Assign Base Address", why the Qsys did not recongnize the width of the bus? why the Qsys did not assign the adress correctly?
