20 years agoNios 5.1, elf2flash ignores base address?
I have just upgraded from Version 5 to Version 5.1 The generated command line is this: elf2flash --input=LynxApp.elf --flash=IC2 --boot=c:/altera/kits/nios2_51/components/altera_nios2/boot_...
20 years agoIf I try the noboot example, I get an error "Boot copier file name required".
The boot copier is required since I run the code in SRAM. What does bother me is the "IC2" reference, which I believe I had used as part of a board description in the previous Quartus version, but which is not visible now (there are no board descriptions showing in SOPC builder).
