13 years agoNios 2 won't run a new software configuration
Hello, I'm experiencing a problem when trying to modify a NIOS 2 based project. The situation stands as follows: I have a working project wrote on a flash. When I try to modify the software, a...
13 years agoDo you use the remote update component or anything else involving a watchdog timer?
Is the fpga configuration stored in flash the same as the one you are supposed to use with the modified Nios sw? Or did you change fpga design, too?
