12 years agonios 2 vs. 16x4 LCD module
Hello everybody,
i'm a student and a newbie at FPGA-programming. Right now i'm working with a DE0-Nano-board and i'm trying to write some characters on a 16x4 LCD-screen. In QSYS i included the LCD-character-module and i tried to use some example source-code. I also found some posts in this forum but nothing really worked out. Maybe it's because the LCD-module in QSYS is especially for the "Optrex 16207". I found the "Optrex 16207 LCD Controller Core" in the "ug_embedded_id.pdf". But it didn't really helped me. I'm using a TM164AAA module http://pdf.datasheetcatalog.com/datasheets2/36/361888_1.pdf I would be very pleased if anyone of you could have a short look on my simple code. Maybe you give me a little hint... I tried different example codes. Please find attached some pictures of my system and the source-code. https://www.dropbox.com/s/q1yqr77xucjc0ld/hardware.jpg https://www.dropbox.com/s/660jtbpz57tyr2x/qsys.jpg https://www.dropbox.com/s/iyfakq3nhugeyjt/system_h.jpg Thank you very much. With best regards, In2GoNo RepliesBe the first to reply
