22 years agoNIOS 2 Instruction Master Address Range
I've down loaded the NIOS 2 tools and installed. I'm converting an existing design to NIOS 2. The design has a large number of FLASH devices; 19 of the 256 MBit type. Also a 259 MBit ...
22 years agoThe CFI Flash component is probably an Avalon-Tristate-Bridge bus interface, not pure Avalon, so you must attach it to the master from an Avalon-Tristate-Bridge. The Avalon-Tristae-Bridge slave is then the slave that you connect the Nios master to so the Nios can access the CFI flash.
