21 years agoNios 2 IDE download verification error
Downloading 00800020 ( 0%) Downloading 00810000 (85%) Downloaded 75KB in 1.6s (46.8KB/s) Verifying 00800020 ( 0%) Verify failed Leaving target processor paused ...
21 years agoHi,
I had the same problem, and someone told me that the nios-download in version5.0 is the first one that checks the memory content after downloading. So for example loading code to areas where no RAM is will not work, because it is checked now. Also loading code to RAM that is only connected to the instruction master of the CPU will not work, this will not work with previuos versions, but you will have a direct error now. Stefaan
