11 years agoNios 2 communication without using nios2-terminal
Hello, I have a board with a NIOS 2 processor connected to a Lnux PC through a USB Blaster cable. I know all the commands for the NIOS 2 and I can communicate from the Linux PC using the nios2-t...
11 years agoSince you're using a Linux host, you could also simply use popen() around nios2-terminal
Depending on the scope of your application, you could probably also accomplish the same task via the dashboard GUI elements (Tcl/Tk) in System Console.
