11 years agoNios 2 communication without using nios2-terminal
Hello, I have a board with a NIOS 2 processor connected to a Lnux PC through a USB Blaster cable. I know all the commands for the NIOS 2 and I can communicate from the Linux PC using the nios2-t...
11 years agoMost dev boards have a serial connection as well as the USB blaster. Usually these are an FTDI or similar serial to USB converter chip. Connect a USB cable from that port to your computer. The port will usually show up in the linux /dev directory. Hint: Do "ls /dev" before and after connecting the cable. The entry that appears when the cable is connected is your serial device. Use standard linux seral port programming from there. Another hint: The command "stty < /dev/<whatever>" will tell you the baud rate etc that the port is set to.
