22 years agoNios 1 vs Nios 2
We have an avionics lighting group in our company that is expanding into newer technology. It is only a matter of time that they will need a super low cost micro solution. I am in a group that desi...
22 years agoOh I almost forgot. Another difference between the two is if you need to optimize your code doing assembly, you'll have a much easier time with NIOS II then with I. I can't tell you how many time I've cursed outloud because I used the wrong cc_xx code due to the reverse logic in NIOS I.
