21 years ago
NIOS 1 Memory Usage
I've got a NIOS system running but have questions about memory usage
(RAM). I've got 2 files that contain the issues. The 1st is the
memory map (.mn) generated by the compiler and the 2nd is a memory
dump captured using hyperterm. Before starting the CPU and capturing
the memory dump, I filled RAM with AAAAs.
The two mysteries
(1) The map indicates we have a total ram of 8192 (I am using all
decimal now) of which 5232 (about 63%) is allocated. That leaves about
2960 available. Included in the 5232 is a block of 1052 associated
with malloc. We suspect this is used for local variable storage that
exceeds the stack BUT what determines this block size?
Looking at our code, we cannot see where we need anywhere near this
amount of RAM for local variable storage. How we make it smaller?
--- ouput of copmiler map file
00040000 A na_ext_ram
00040000 A nasys_usersocket_1
00040000 A nasys_vector_table
00040100 A _nasys_data_destination
00040100 A nasys_data_mem
00040100 A nasys_vector_table_end
00040100 D _data
00040100 D nS
00040104 D x
00040124 D y
... Deleted variable listing for clarity
00040abc D testStr
00040ad8 D RAMLimit
00040adc d inited.0
00040ae0 d inited.1
00040ae4 d impure_data
00040dd0 D _impure_ptr
00040dd4 D __mb_cur_max
00040dd8 d lc_ctype.0
00040de0 d last_lc_ctype.1
00040de8 D __malloc_av_
000411f0 D __malloc_trim_threshold
000411f4 D __malloc_top_pad
000411f8 D __malloc_sbrk_base
000411fc D __malloc_max_sbrked_mem
00041200 D __malloc_max_total_mem
00041204 D __malloc_current_mallinfo
0004122c A __bss_start
0004122c A _nasys_uninitialized_storage
0004122c B _bss
0004122c D _edata
0004122c D _nasys_data_destination_end
0004122c b xAvg.48
00041234 b yAvg.49
0004123c b sAvg.50
00041244 B _nr_userisrtable
00041444 B atexit_func
00041448 B _main_return
0004144c B cwpUnderflowG
0004146c B errno
00041470 A _end
00041470 A _nasys_uninitialized_storage_end
00042000 A na_ext_ram_end
00042000 A nasys_data_mem_end
00042000 A nasys_stack_top
(2) When I run the program and dump the RAM, you can see that data
(non AA values) occur through the first 5232 locations. Then there are
some AA's followed by a large section of RAM with non AA's. In fact,
it appears something is using another 2004 of RAM out of the available
2960. This wipes out our growth capability. What is using up this RAM
and how do we prevent it?
Memory Dump-------------------
040000: 3641 000C 392F 000C 398A 000C 3641 000C
040010: 3641 000C 3641 000C 3641 000C 3641 000C
040020: 3641 000C 3641 000C 3641 000C 3641 000C
RAM contains mostly 0000s as expected.
040D10: 0000 0000 0000 0000 0000 0000 0AE4 0004
040D20: 0000 0000 0000 0000 0000 0000 0009 0001
040D30: 0000 0000 0000 0000 0000 0000 0D20 0004
040D40: 61FD 000C 621E 000C 624B 000C 6273 000C
Looks like this RAM contains the address of itself
Probably a Malloc event.
040DF0: 0DE8 0004 0DE8 0004 0DF0 0004 0DF0 0004
040E00: 0DF8 0004 0DF8 0004 0E00 0004 0E00 0004
040E10: 0E08 0004 0E08 0004 0E10 0004 0E10 0004
040E20: 0E18 0004 0E18 0004 0E20 0004 0E20 0004
This pattern continues
0411C0: 11B8 0004 11B8 0004 11C0 0004 11C0 0004
0411D0: 11C8 0004 11C8 0004 11D0 0004 11D0 0004
0411E0: 11D8 0004 11D8 0004 11E0 0004 11E0 0004
Here starts a lot of Zeros..
0411F0: 0000 0002 0000 0000 FFFF FFFF 0000 0000
041200: 0000 0000 0000 0000 0000 0000 0000 0000
041210: 0000 0000 0000 0000 0000 0000 0000 0000
Continuing till
041440: 0000 0000 0000 0000 20FB 0008 0000 0000
041450: 0000 0000 0000 0000 0000 0000 0000 0000
041460: 0000 0000 0000 0000 0000 0000 0000 0000
An then untouched memory.
041470: AAAA AAAA AAAA AAAA AAAA AAAA AAAA AAAA
041480: AAAA AAAA AAAA AAAA AAAA AAAA AAAA AAAA
041490: AAAA AAAA AAAA AAAA AAAA AAAA AAAA AAAA
0414A0: AAAA AAAA AAAA AAAA AAAA AAAA AAAA AAAA
Till this which looks like stack usage
041780: AAAA AAAA 4141 4141 0041 0000 0003 0000
041790: FFFF FFFF FFFF FFFF 0000 0000 0031 0000
0417A0: 0300 0004 5C75 000C FF20 0000 0000 0000
0417B0: 0000 0000 0000 0000 56EC 000C AAAA AAAA
0417C0: AAAA AAAA AAAA AAAA AAAA AAAA AAAA AAAA
Up to the end of RAM or the Start of Stack.
041F40: 6DB0 3FE1 0000 0000 9800 40EA 5CBC 77C4
041F50: D662 3FEA 0000 0000 79B0 40F4 AAAA AAAA
041F60: AAAA AAAA AAAA AAAA AAAA AAAA AAAA AAAA
041F70: AAAA AAAA AAAA AAAA AAAA AAAA AAAA AAAA
041F80: AAAA AAAA AAAA AAAA AAAA AAAA AAAA AAAA
041F90: AAAA AAAA AAAA AAAA AAAA AAAA AAAA AAAA
041FA0: AAAA AAAA AAAA AAAA AAAA AAAA AAAA AAAA
041FB0: AAAA AAAA AAAA AAAA AAAA AAAA AAAA AAAA
041FC0: AAAA AAAA AAAA AAAA AAAA AAAA AAAA AAAA
041FD0: AAAA AAAA AAAA AAAA AAAA AAAA AAAA AAAA
041FE0: AAAA AAAA AAAA AAAA AAAA AAAA AAAA AAAA
041FF0: AAAA AAAA AAAA AAAA AAAA AAAA AAAA 0862
    Thanks to a ll replies.
    1. malloc:
    Help, who's calling malloc and how do we track that down? In the objdump file we can't find the call to malloc using grep. Yes we're using the standard libraries. We are using sin, cos and atan functions.
    2. stack usage:
    The code is not called more that 4 deep. The stack set in the hardware is 31 deep. From the memory dump it looks like the stack is being rolled out of the hardware and into the RAM. Disabling the CWP manager will probably just crash the system. but it's a test to run.
    No. None of the replys hold the answer or even a path to finding the answer.
    George
