22 years agoNIOS 1 Memory Usage
I've got a NIOS system running but have questions about memory usage (RAM). I've got 2 files that contain the issues. The 1st is the memory map (.mn) generated by the compiler and the ...
22 years agoI believe that the answer is to use the new Nios II memories. Is it possible to switch to Nios II?
I'll try to get you more info on the problem.
