15 years agoNIOS + IRQ + custom component
Hi, I'm trying to interrupt a Nios Prosessor whit a Custom Component and setup a successful interrupt routine. But I can't Do it. The problem is that i can't find a complete example of a custo...
15 years agoOn the nios your avalon slave will see the write cycle before the cpu executes the next instruction (provided you've not gone through the cache!).
You might want to check reads and writes from the nios to your mm slave work properly!
