15 years agoNIOS + IRQ + custom component
Hi, I'm trying to interrupt a Nios Prosessor whit a Custom Component and setup a successful interrupt routine. But I can't Do it. The problem is that i can't find a complete example of a custo...
15 years agoYou need to close the loop with the ISR.
The nios interrupts are level sensitive, so if the hardware removes the IRQ signal (to the cpu) and the cpu was running with interrupts disabled, then the interrupt wont be detected.
