15 years agoNIOS + IRQ + custom component
Hi, I'm trying to interrupt a Nios Prosessor whit a Custom Component and setup a successful interrupt routine. But I can't Do it. The problem is that i can't find a complete example of a custo...
15 years agoOh - you also want to add a 2nd MM slave register so that the nios code can disable interrupts without regard for what the hardware is actually doing.
This could feed in either side of the 'or' of the multiple IRQ sources.
