14 years agoNIOS : IOWR works fine but writing through a pointer not
I have two problems with a generic NIOS system with data and instruction caches. 1. A Avalon MM slave is attached to NIOS system. A write to the slave is successful through IOWR. However, wit...
14 years agoOK, I'll try this to check the burst transfer. There is appreciable cycle gap between two writes (IOWR) or reads (IORD) even if two write/read statements are placed next to each other with no other expression in between.
Regarding the pointer access, somehow, I have not been able to force a write or read transaction with pointers (not using the stio IOWR/IORD). As mentioned earlier the pointer expression below is not generating an write transaction on the slave port. int *PtrToSlave = (int *) Avalon_MM_Slave_Base; // Slave base address *PtrToSlave = (int) data;
