16 years agoNIOS : INTERNICHE stack without ucOSII
Hello I'd like to use the interniche stack and the TSE ethernet mac, but without ucOSII.. I've heard, it exist a superloop example but it seems a lot of files patching is mandatory. D...
16 years agodsl you are right, if you want a bandwith that is significant over fast ethernet you need hardware acceleration. To achieve about 640 MBit/s data rate I had to offload the whole UDP protocol, but for controlling the user application the TCP/IP stack is fast enough.
There is an app note (AN440) for accelerating ethernet applications. Checksum offload through custom instructions is also described. Jens
