16 years agoNIOS : INTERNICHE stack without ucOSII
Hello I'd like to use the interniche stack and the TSE ethernet mac, but without ucOSII.. I've heard, it exist a superloop example but it seems a lot of files patching is mandatory. D...
16 years agoI'm really pleased.
Belonging dependencies I'm not sure. In some sources, e.g. in C:\altera\91\nios2eds\components\altera_iniche\HAL\src\alt_iniche_read.c is a# include "system.h". Thats a broad hint to system-dependency. But I don't know what they do in detail. When using TSE and Iniche you need a few components in each SOPC (SGDMA_TX, SGDMA_RX, DESCRIPTOR_MEMORY) which will referenced by the libraries. My solution is actually to have 2 virtual machines. One with 9.1 SP1 for building firmware and another with SP2 for synthesis (needed for C4E). I didn't test if the Simple Socket Server in superloop works in 9.1 without SP or with SP2. You should try it out! Jens
