16 years agoNIOS : INTERNICHE stack without ucOSII
Hello I'd like to use the interniche stack and the TSE ethernet mac, but without ucOSII.. I've heard, it exist a superloop example but it seems a lot of files patching is mandatory. D...
16 years agoHello,
thanks for posting the patches! Unfortunately I can not apply the patches. create-this-bsp works, but patching the libraries always results in the error-code bellow (e.g. when trying to patch the interniche library. same problem with TSE lib ). Any ideas about the reasons? thanks a lot, Frank --- Quote Start --- [NiosII EDS]$ ./create-this-lib Copying library sources from installation tree... ................................................................................ ................................................................................ ................................................... create-this-lib: Running "nios2-lib-generate-makefile --bsp-dir ../bsp --lib-dir . --lib-name superloop_iniche --src-rdir ./iniche/ --public-inc-dir ./iniche/i nc --public-inc-dir ./iniche/src/h --public-inc-dir ./iniche/src/h/nios2 --publi c-inc-dir ./iniche/src/nios2 --set LIB_CFLAGS_DEFINED_SYMBOLS -DSUPERLOOP -DALT_ INICHE -DALTERA_TRIPLE_SPEED_MAC --set LIB_CFLAGS_OPTIMIZATION -O0 " INFO: nios2-lib-generate-makefile --bsp-dir ../bsp --lib-dir . --lib-name superl oop_iniche --src-rdir ./iniche/ --public-inc-dir ./iniche/inc --public-inc-dir . /iniche/src/h --public-inc-dir ./iniche/src/h/nios2 --public-inc-dir ./iniche/sr c/nios2 --set LIB_CFLAGS_DEFINED_SYMBOLS -DSUPERLOOP -DALT_INICHE -DALTERA_TRIPL E_SPEED_MAC --set LIB_CFLAGS_OPTIMIZATION -O0 INFO: Generating library makefile FINE: Generated file ".\Makefile" FINE: Generated file ".\public.mk" INFO: Library makefile generated patching file ../iniche/src/h/nios2/ipport.h Hunk# 1 FAILED at 1. 1 out of 1 hunk FAILED -- saving rejects to file ../iniche/src/h/nios2/ipport.h. rej patching file ../iniche/src/h/sockvar.h patching file ../iniche/src/nios2/targnios.c Hunk# 1 FAILED at 1. 1 out of 1 hunk FAILED -- saving rejects to file ../iniche/src/nios2/targnios.c. rej patching file ../iniche/src/tftp/tftpcli.c Hunk# 1 FAILED at 1. 1 out of 1 hunk FAILED -- saving rejects to file ../iniche/src/tftp/tftpcli.c.re j patching file ../iniche/src/tftp/tftpsrv.c patching file ../iniche/src/tftp/tftputil.c patching file ../iniche/src/allports/timeouts.c create-this-lib: Running make Info: Building ../bsp/ make --no-print-directory -C ../bsp/ [BSP build complete] Info: Compiling iniche/src/allports/allports.c to obj/iniche/src/allports/allpor ts.o nios2-elf-gcc -xc -MP -MMD -c -Iiniche/inc/ -Iiniche/src/h/ -Iiniche/src/h/nios2 / -Iiniche/src/nios2/ -I../bsp/ -I../bsp//drivers/inc -I../bsp//HAL/inc -DSYSTE M_BUS_WIDTH=32 -D__hal__ -pipe -DALT_NO_INSTRUCTION_EMULATION -DALT_SINGLE_THREA DED -DSUPERLOOP -DALT_INICHE -DALTERA_TRIPLE_SPEED_MAC -O0 -g -Wall -mno-hw- div -mhw-mul -mhw-mulx -o obj/iniche/src/allports/allports.o iniche/src/allport s/allports.c In file included from iniche/src/allports/allports.c:26: iniche/src/h/nios2/ipport.h:506:22: includes.h: No such file or directory In file included from iniche/src/h/nios2/ipport.h:507, from iniche/src/allports/allports.c:26: iniche/src/h/tk_crnos.h:115: error: syntax error before '*' token iniche/src/h/tk_crnos.h:115: warning: type defaults to `int' in declaration of ` rcvdq_sem_ptr' iniche/src/h/tk_crnos.h:115: warning: data definition has no type or storage cla ss In file included from iniche/src/allports/allports.c:77: iniche/src/allports/../nios2/osport.h:25:22: includes.h: No such file or directo ry make: *** [obj/iniche/src/allports/allports.o] Error 1 --- Quote End ---
