22 years agoNios & Flash
Can the Nios cores handle the synchronous and/or burst modes of particular Flash devices in regards to instruction fetch?
22 years ago(As the "Software Guy", I thought I'd chime in.)
The real question here is how to run the application program from Flash while keeping the execution speed up of the NIOS-II processor. For example, a 110 ns read access Flash (fairly standard, can get faster) means that the processor can fetch instructions at 1/110 ns or 9.09 MHz rate. Of what good is running at 100 MHz clock speed if you're limited by the Flash? Unfortunately, the option of copying from Flash to SRAM and running from the faster SRAM isn't available to us. "uiliak" found some burst-mode Flash, but that requires the instruction pre-fetch to understand this mode, and I have reservations on how useful this would be in a "random-access"-type program anyway. So, if you're running your application out of Flash, how do you keep it from being the bottleneck? Any clues out there from people who run their apps from Flash? John
