VViro
8 years agoNios - II memory alignment issue while accessing integer from non word align location
Error Msg : Not getting any error message but getting unexpected behavior - Using Nios-II with eclipse. While accessing integer(32 bit) form non word align location getting incorrect value as descri...
- 7 years ago
Hi Vasu,
Try by going to the project folders > right-click > properties> Nios II Application properties >
Debug Level = 2
Optimization Level =2
This gives the required output
Anand Raj Shankar
VViro
8 years agoAnand,
We have tested it with Cyclone III (CoreCommander Board), Max 10 (DECA Board) and Cyclone 10 GX (custom board). But seeing same issue with all of them.
Which FPGA board you are using to test this? Can you share Quartus design?
We are using default settings in eclipse. Have you made any change in eclipse settings?
Vasu.
