16 years agoNicheStack multiple select() call fails!
Hello @ all, I have created two (or more) networktasks in the µC/OS-II enviroment wich are using the Niche TCP/IP Stack. When i perform a select() call from both tasks to there sockets, only the s...
16 years agoI saw the same thing as you... The application worked fine with the Nios II 8.0 IDE, and started to get synchronization problems when we switched to 9.0. The TCP_WAKE define solved it, but we still have a crash of the TCP/IP stack about every 2-3 days. But those crashes could be unrelated to this synchronization problem.
Since then we changed of operating system and don't use the Interniche stack any more, so I didn't investigate the matter further.
