16 years agoNicheStack multiple select() call fails!
Hello @ all, I have created two (or more) networktasks in the µC/OS-II enviroment wich are using the Niche TCP/IP Stack. When i perform a select() call from both tasks to there sockets, only the s...
16 years agoTry to edit your ipport.h file. Look for these lines:
/* use the sleep/wakeup in misclib/netmain.c */
//#define TCPWAKE_RTOS 1and uncomment the define. It's not rock-solid, but it's a lot better. Nevertheless I wouldn't recommend to use the Interniche stack from multiple tasks in production code... or I would recommend to stick to 8.1
