16 years agoNicheStack multiple select() call fails!
Hello @ all, I have created two (or more) networktasks in the µC/OS-II enviroment wich are using the Niche TCP/IP Stack. When i perform a select() call from both tasks to there sockets, only the s...
16 years agoThere is a further suspicious thing...
When is used the original implementation, wich comes out with the 8.1 design-suite, it seems that there is no problem with multiple selects() in general. But these implementation has the issue that sometimes the select doesn't return when rceiving tcp-pakets. So i decided to install the altera patch.
