12 years agoNiche "Zero copy" mode trouble: buffer overflow
Hello. I am trying to launch "Zero copy" mode of the TCP data transmission with Niche stack. It seems to be living, but after some amount of packets the transmission buffer overflows (tcp_xou...
12 years agoI've solved this all and now it works.
The problem was in lack of time for receiving task, so it could not receive ACK frames. I've wrote such code: do { e = tcp_xout(conn->fd, pkt); if (e < 0) { if (e == ENP_RESOURCE) tk_yield(); /* let the system spin once */ else { tcp_pktfree(pkt); return; } } } while (e == ENP_RESOURCE); It works... But it works even slower than using send() function. So, there is no benefit from using "Zero copy", though I am eliminating one copy process of the data. Can anybody help to explain such behaviour? What is wrong?
