AAndyy
4 years agoNewlib getc() hangs the program
Using the web edition of Quartus Prime rev 18.1 .
Implementing a NIOS II based design in a Max10 chip.
Using the standard C library function calls that Newlib supports.
I have verified that get...
EBERLAZARE_I_Intel
4 years agoHi,
Could you share the build log for the newlib? I presume it was successful/completed based on your description. And the issue is related to its functionality of your custom design. Is the issue also with other designs or any example design that you have tried? OR is it only on a particular custom design that you have tested?
