21 years agonewbie to uClinux, having install problem
Hello, This is my first attempt with installing uClinux1.3. I am using Quartus 4.1 SP2 and nios II 1.01 currently. I am trying to run this on a stratix2s60 altera dev kit. When installing the ...
21 years agoOkay sorry to bring this back up again, but I finally have a resolution.
I re-installed from scratch the entire group of apps starting with Quartus v4.2 with everything default, then the service pack 1. Then I installed Nios v1.1 and finally the uClinux v1.3. There is no problem anymore with the installation. I did not want to do this earlier because things were already working except for uClinux kernel development. So hopefully for those with similar problems, i would recommend a total clean install of everything and leave the Quartus to install most of the defaults... i think my mistake the first time was i was selective of certain components to install. I did re-install Nios dev kit over and over again several times but it was Quartus re-install that did the trick. -Quan
