21 years agonewbie to uClinux, having install problem
Hello, This is my first attempt with installing uClinux1.3. I am using Quartus 4.1 SP2 and nios II 1.01 currently. I am trying to run this on a stratix2s60 altera dev kit. When installing the ...
21 years agoHello,
for all who are experiencing the "cannot open crt0.o: No such file or directory" problem, open up a Nios II SDK shell window and run "mount" This will display your Cygwin's mount table. When you initially install Quartus II (and its included Cygwin), one of the mount entries is:C:\altera\quartus42\bin\cygwin\lib on /usr/lib type system (textmode) The Nios II Linux install process should remove this entry. If for some reason this mount entry still exists, you will experience the crt0.o problem. To remove this entry, simply unmount /usr/lib by running this command in a Nios II SDK shell window: umount /usr/lib I hope this helps.
