21 years agonewbie to uClinux, having install problem
Hello, This is my first attempt with installing uClinux1.3. I am using Quartus 4.1 SP2 and nios II 1.01 currently. I am trying to run this on a stratix2s60 altera dev kit. When installing the ...
21 years agoHey guys,
I think jmastron was onto something. I'm not very profiecient with linux but it looks like that process is looking in the wrong directory. If you go to /usr/lib and copy over the files crt0.o and libcygwin.a over into the /usr/local/lib folder, then you should be able to get onto the next stage of error, something about the curse.h file. And i believe that someone on this site has already figured that one out, gonna do a search. My guess is I have one or more of my settings incorrect somewhere... OOPS... had to remove stupid comment..... I'm off to find this curses.h file thing now. -Quan
