21 years agonewbie to uClinux, having install problem
Hello, This is my first attempt with installing uClinux1.3. I am using Quartus 4.1 SP2 and nios II 1.01 currently. I am trying to run this on a stratix2s60 altera dev kit. When installing the ...
21 years agoI also have a similar problem. I started a new project this week, so I removed QuartusII 4.1, NiosII 1.01, and uClinux 1.2 off of my machine. Started off clean with QuartusII 4.2 SP1, NiosII 1.1, and uClinux 1.3. The Quartus and Nios IDE environments seem to be working correctly; however, when I installed uClinux 1.3 I received 2 errors at the end of the installation. Both were looking for cygwin.dll, and were unable to do so.
After several attempts, I tried to go back to uClinux 1.2. No luck here, it is specifically looking for NiosII 1.01. I tried the installation again, this time using add/remove programs instead of using "Run" from the start button. Perhaps this is the way you're supposed to do it anyway, please excuse my ignorance of windows. Anyway, the installtion went fine this time, no reported errors. When I try to "configure kernel." I also get an error that is too fast to catch. My user.bashrc reflects Version 1.3, Built December 30th, 2004.
