21 years agonewbie to uClinux, having install problem
Hello, This is my first attempt with installing uClinux1.3. I am using Quartus 4.1 SP2 and nios II 1.01 currently. I am trying to run this on a stratix2s60 altera dev kit. When installing the ...
21 years agoHi Ken,
I've just received the Nios2 v1.1 upgrade and installed that and then re-installed the uClinux v1.3 along with Quartus II v4.2. I do not experience the problem any more but still is related is that I cannot configure the kernel. A message pops up and goes away pretty quick, but I can make out some of the message. It was complaining about a missing file, first it was user.bashrc. I copied over an older user.bashrc file. Then at some other point, it was complaining about not haing a cr0t.0 file or something like that when it tried to perform an ld command. Below are the answers to your previous question, just incase it will help me out. (1) Location of the Altera Nios II Distribution (defaults to c:\altera\kits\nios2) C:\altera\kits\nios2 (2) Location of Quartus II (defaults to c:\altera\quartus42) C:\altera\quartus42 (3) value of QUARTUS_ROOTDIR environment variable C:\altera\quartus42 -Quan
