15 years agoNewbie regarding NIOS - can I mix VHDL with NIOS in Cyclone III
Hello, I've been using Altera CPLDs and FPGAs strictly with VHDL code. I just learned about NIOS options for the chips. If I implement a NIOS processor in my Cyclone III, can I still run independe...
15 years agoif you have enough resources you can run Nios processor(s) and "user logic" (VHDL code)
you could approach the design in a number of ways. the easiest would be to instantiate an SOPC Builder/Qsys system into your VHDL code. the simplest way to interface a Nios to VHDL code would be a parallel I/O component you could also design your VHDL with Avalon Memory Mapped and Streaming interfaces, and populate them within SOPC Builder/Qsys and interface directly with the Nios II processor
