16 years agoNewbie question: driving leds
Hello everybody! I'm an absolute newbie in Altera / NIOS. I have an NEEK with Cyclon III and touch panel LCD. But for the time being, I am studying the basics. I have been through the ...
16 years agoHi Pascal. Have you corrected the pinning? In the Example Designs there are fault Pin-Assignements for the LEDs. Try to correct them and try again. The Pins you can find in the reference_manual for the NEEK.
Edit: I have looked that up you can find a running example under NIOS_Evaluation_Kit_v8.0\cycloneIII_3c25_niosII\examples\cycloneIII_3c25_start_my_first_fpga the Pins are: PIN_P13 PIN_P12 <- this is wrong in "standard" it's PIN_T1 there PIN_N12 PIN_N9 Good Luck.
