20 years agoNewbie Help - ISR Context ptr vs. Global
Hello, I'm working on my first Nios II project and am trying to figure out what advantage there is to using an ISR's context pointer. Typically with all my other MCU projects, I simply...
20 years agoWhen you use C++ to develop your code, you'll need the context pointer to pass object pointer to ISR. Because ISR should be static.
FYI.
